XHISADD
Bulk Data Entry Defines a time history output set as a union of time history outputs defined via XHIST entries.
| XHISADD | SID | S1 | S2 | S3 | S4 | S5 | S6 | S7 | |
| S8 | S9 | etc. |
| XHISADD | 101 | 2 | 3 | 1 | 6 | 4 |
| SID | Set identification
number. (Integer ˃ 0) |
| Sj | Set identification numbers
of time history output defined via XHIST entries.
Must be unique and may not be the identification number of a rigid
wall set defined by another XHISADD
entry. (Integer ˃ 0) |
- Multipoint constraint sets must be selected with the Subcase Information command XHIST=SID.
- XHISADD entries take precedence over XHIST entries. If both have the same SID, only the XHISADD entry will be used.
- This card is represented as a load collector in HyperMesh.
