RADPRM
Bulk Data Entry Defines the parameters for explicit dynamic analysis.
RADPRM PARAM1 VALUE1 PARAM2 VALUE2 PARAM3 VALUE3 PARAM4 VALUE4
  PARAM5 VALUE5
RADPRM HMNAME YES RBE2RBD YES
PARAMi Name of parameter. 2
VALi Value of parameter.
  1. The parameters defined by RADPRM bulk card are only applied in explicit dynamic analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
  2. The parameters PARAM, NLAFILE, PARAM, NLRFILE, PARAM, NLRUN, and PARAM, SNAPTHRU can also be defined by PARAM Bulk card (for these parameters, the PARAM card is now deprecated). However, if any of these parameters is defined by both PARAM and RADPRM cards at the same time, PARAM definition is ignored and RADPRM is used.
