PARAM, HDF5
Bulk Data Entry Controls the output format of the Hierarchical Data result file (HDF5).
| Parameter | Values | Description |
| HDF5 | <FORM1, FORM2, BOTH> |
- The old format (.hdf5) does not contain finite element model information and hence, requires importing the model file, in addition to importing the result file in a post-processor.
- The new format (.h5) contains both model and result information and hence can be used for post-processing directly.
