PARAM, LSNLEXP
Bulk Data Entry In the nonlinear solution that has difficulties converging, the “expert system” will try, among other remedies, activation of Line Search.
| Parameter | Values | Description |
| LSNLEXP | <YES, NO, AUTO> |
- When Line Search is activated explicitly on the NLPARM card, then it will be active (where applicable) irrespective of this parameter.
