PARAM, FLIPOK
Bulk Data Entry Allows tetrahedral elements to invert during shape optimization.
| Parameter | Values | Description |
| FLIPOK | <YES, NO> |
- PARAM, FLIPOK, YES can be introduced to force OptiStruct to run models with severely distorted and possibly inverted elements (CTETRA/CTRIA3). Since such models contain severely distorted and inverted elements, it is your responsibility to further validate the analysis or optimization results for accuracy, if this parameter is used.
