PARAM, AUTOSPC
Bulk Data Entry Automatically constrain degrees-of-freedom with no stiffness.
| Parameter | Values | Description |
| AUTOSPC | <YES, NO> |
- PARAM, AUTOSPC is generally applicable only to grid points (with unconstrained DOF) attached to structural elements.
- Rotational DOF of grid points that are connected only to solid elements are automatically constrained in the pre-processor and are not affected by PARAM, AUTOSPC.
- Free grid points are also automatically constrained in the pre-processor and are not affected by PARAM, AUTOSPC.
- The list of grids with degrees of freedom that were constrained by the second round of AUTOSPC is output to the .HM.comp.tcl file.
- The SPCOFF and SPCOFF1 Bulk Data Entries can be used to exclude degrees-of-freedom from AUTOSPC.
