PARAM, EXCOP2
Bulk Data Entry This parameter controls the output of the AVL EXCITE _AVL.op2 file directly from OptiStruct.
Parameter Values Description
EXCOP2 <YES, NO> This parameter controls the output of the AVL EXCITE _AVL.op2 file directly from OptiStruct.
YES (Default)
The AVL EXCITE _AVL.op2 file is output.
NO
The AVL EXCITE _AVL.op2 file is not output.
