PARAM, MFILTER
Bulk Data Entry Defines a threshold for the mode tracking matrix to check eigenvector correspondence.
| Parameter | Values | Description |
| MFILTER | <0.0 ≤ real number ≤
1.0> Defaults:
This parameter defines a
correspondence. If an entry of the mode tracking matrix is greater than the specified threshold, the eigenvectors of previous and current iterations (corresponding to the row number and column number of the entry) are assumed to have correspondence. If PARAM, TRAKMETH is set to 0, the mass matrix based cross-orthogonality criterion (CORC) is used to check for eigenvector correspondence, and PARAM, MFILTER is set to 0.7. If PARAM, TRAKMETH is set to 1, the modal assurance criterion square root (MACSR) is used, and PARAM, MFILTER is set to 0.7. If PARAM, TRAKMETH is set to 2, the modal assurance criterion (MAC) is used and PARAM, MFILTER is set to be 0.5. |
