| This parameter specifies
the scale factor (q) used to
calculate the Sound Pressure Level in Radiated Sound Analysis. The
equation used for the calculation is: Sound Pressure
Total
Complex Acoustic Sound Pressure requested by SPL
is:
Where,
- Frequency of the sound wave in the medium.
- Density of the acoustic medium defined by PARAM, SPLRHO.
- Distance from the acoustic source grid
on the panel to the
microphone location grid.
- Velocity flux of the source grid
- Wave number as defined in Wave Number.
- Square root of -1.
- Number of source grids.
- Value of the scale factor specified using the
parameter PARAM,
SPLFAC.
