| EXTOUT |
<DMIGPCH,DMIGBIN,
DMIGOP2, DMIGOP4> |
<DIGITS> Default = 16
- DMIGPCH (Default)
- The matrices are written to an ASCII
.pch file.
- DMIGBIN
- The matrices are written to a binary
.dmg file.
- DMIGOP2
- The matrices are written to the
.DMIGOP2 file. This option is
only available for CMS Super Elements. This output is
not supported for static reduction. This is a binary
file. The mass, stiffness, viscous damping, and
structural damping matrices, as well as the interface
GRID and components are written
to the .op2 file.
- DMIGOP4
.op4 file. This option is only
available for CMS Super Elements. This output is not
supported for static reduction. This is an ASCII file. The mass,
stiffness, viscous damping, and structural damping
matrices are written to the .op4
file. The OUTPUT4 FORMAT is 1P,rEw.d where d=DIGITS and
w=d+7. The number of columns is the integer portion of
r=80/w. So, the default value of 16 gives the format
1P,3E23.16.
- Additional files with the extension
.USET are written. This file
contains the USET U1 data for the
connection points as well as SPOINT
data for the modal degrees of freedom.
Refer to Direct Matrix Input (Superelements) in the User
Guide for more detailed information.
