PARAM, EXCOUT
Bulk Data Entry Output of condensed superelement information for AVL/EXCITE to the corresponding output files.
| Parameter | Values | Description |
| EXCOUT | <-1, 0, 1, 3, 4, 5, 6> | Output of
corresponding output files. 3 This parameter is now obsolete,
use PARAM,EXCEXB.
- When PARAM,EXCOUT,1 is specified and the MODEL I/O Options Entry is not defined, then only the ASET DOF are output. The other data, like non-ASET DOF, geometry, element tables and so on (see 1 above) are NOT output in this particular case.
- For all other options, except PARAM,EXCOUT,1, the MODEL=ALL command is enforced regardless of user input. Therefore, for PARAM,EXCOUT,0/3/4/5/6, the corresponding output listed above for each option is generated for the entire model and the user-defined MODEL entry is ignored.
- The results are output to the .doft, .geom, MEIG.out2, _MGPS.out2, .out2, _MFF.out4, _X2OA.out4, and .out4 files.
