PARAM, EFFMAS
Bulk Data Entry Outputs modal participation factors and effective mass for normal modes analyses.
| Parameter | Values | Description |
| EFFMAS | <YES,
NO, Integer> Default = NO |
When
EFFMAS ≤ 0 or
NO, the modal participation factors, modal
participation factor ratio, modal effective mass and modal effective
mass fraction are not output for normal modes analysis. When EFFMAS > 0 or YES, the modal participation factors, modal participation factor ratio, modal effective mass, and modal effective mass fraction will be computed and output to the .out and .pch files (OUTPUT,PUNCH should be active for .pch file output) for normal modes analysis. They are computed as: Modal Participation Factor = The Modal Participation Factor is a measure of how close each mode is to a rigid body mode. The Modal Participation Factor Ratio is the Modal Participation Factor for each rotational and translational direction divided by the maximum Modal Participation Factor of all the modes for that direction. So, each of the six directions will have a value of 1.0 for the mode that has the maximum Modal Participation Factor and the other modes will have a value less than 1.0. Modal Effective Mass = The Modal Effective Mass is a measure of how much mass is associated with each mode. Modal Effective Mass Fraction = The Modal Effective Mass fraction is a ratio of Modal Effective mass and the Rigid Body mass. Where,
