LATPRM, POROSITY
Bulk Data Entry This parameter controls the amount of intermediate densities in the model in the first phase of the Lattice Structure Optimization run.
| Parameter | Values | Description |
| POROSITY | <HIGH, MED, or LOW> | For lattice cells the
homogenized Young's modulus to density relationship is approximated
as E = ρPE0, where E0 denotes
Young's modulus of the dense material and P is the penalty value.
Varying levels of lattice/porous domains in topology results are
controlled by the parameter POROSITY which
adjusts the penalty (P).
