DOPTPRM, MATINIT
Bulk Data Entry Defines the initial material fraction.
| Parameter | Values | Description |
| MATINIT | Real between 0.0 and 1.0, or ANALYSIS | For Topology and Free-Size
optimization runs with mass as the objective, default is 0.9. For
runs with constrained mass, the default is reset to the constraint
value. If mass is not the objective function and is not constrained,
the default is 0.6.
The MATINIT continuation line on the DTPL or DSIZE Bulk Data Entries take precedence over DOPTPRM,MATINIT. |
