SWLDPRM, NREDIA
Bulk Data Entry Maximum number of times the diameter (which is used in locating auxiliary points) is reduced by half when not all auxiliary points have projections onto the patch of shells.
| Parameter | Values | Description |
| NREDIA | 0 ≤ Integer ≤
4 Default = 0 |
This parameter is for CWELD (PARTPAT and ELPAT) only. |
