SWLDPRM, GSTOL
Bulk Data Entry Presently it only applies to CSEAM. Maximum distance between GS-SA, GS-SB, GE-EA and GE-EB for CSEAM.
| Parameter | Values | Description |
| GSTOL | Real ≥ 0.0 Default = 0.0 |
If the distance is
greater than GSTOL, then the connector
element will not be generated and an error will be issued. If
GSTOL is set to 0.0,
the program will skip the checking of
GSTOL.
