Finding variable references
There are two ways to find variables in your diagram:
•      Use Edit > Find and activate Match Variables Only
•      Right-click the variable block and click on Find Ref
Note: If a variable is contained in a state chart or a submachine state, when you search for it, either state chart block or submachine state is highlighted. To find the variable, look in the State Chart Block Properties dialog box or Submachine State Properties dialog box.
