Configuring the editing environment and setting editing options
You use the parameters in the Preferences tab to configure the editing environment and set editing options. The parameters you activate are in effect for the current diagram and all subsequently opened diagrams.
Auto Connect Radius
Auto Save
Color Compound Block
Color Display
Do Not Snap to Grid on the Top Level
High Precision Display
Reload Last Diagram at Startup
Show Horizontal and Vertical Scroll Bars
Show Printable Area
Snap to Grid
Stack Internal Compound Connectors
Text Editor Path
Use Rich Text Format
Warn of Conflicting Local Alias Definitions
