Setting the default text editor
Some blocks and commands use a text editor to view data specific to the block or command. The default text editor is Notepad; however, you can change the default using the Edit > Preferences command.
To set the default text editor
1.    Choose Edit > Preferences > Preferences.
2.    After Text Editor Path, click … to search for and select a text editor.
3.    Click OK, or press ENTER.
