Changing or deleting a password
1.    Open the source file that contains the compound block to whose password is be changed or deleted.
2.    CTRL+right-click the compound block, or choose Edit > Block Properties and click the block.
3.    In the Password box, select the row of asterisks that represent the existing password and do one of the following:
•      To change the password, type in a new password.
•      To delete the password, press the DEL key.
4.    Click OK, or press ENTER.
5.    If you entered a new password, Embed asks you to re-enter the new password for verification.
