By changing the viewing mode, you can change the appearance of your diagrams. When you change the viewing mode, all blocks are changed in accordance to the mode.
To change the viewing mode
1. Choose View from the menu bar.
2. Select one or more of the following options.
Mode |
How it affects blocks |
Presentation Mode |
Hides input connector tabs and shrinks output connector tabs. |
Display Mode |
Hides wires and connectors, freezes blocks in place,
and except for interactive elements on buttons and sliders, locks block
parameter values. If you have inserted a Display Image block in the diagram, it will
not be seen until you simulate the diagram. |
Data Types |
Colors connector tabs according to their data type. |
Block Labels |
Displays user-specified labels below the blocks. If a
block does not have a label, its block name or parameters are
displayed. |
Connector Labels |
Displays user-specified labels next to the tab or in the pop-up text when you probe a signal. |
