Using OpenVision for Image Processing
Image processing refers to the manipulation or analysis of digital images. Typically, image processing is used to enhance or alter the appearance of an image or to examine the image for patterns. Image processing is used in a variety of applications, including:
•      Industrial inspection and quality control
•      Facial and gesture recognition
•      Surveillance and security
•      Traffic monitoring
•      Autonomous driving
•      Medical image analysis
The OpenVision block set takes advantage of the OpenCV library (opencv.org), which is a reference library in the image processing domain.
