Category: Other Tools > Transforms
The Clarke Transform block performs a Clarke forward transform (2 X 2).
The Clarke Transform block provides a magnitude invariant transformation of 3-phase signals/systems, components [a b] to orthogonal reference frame components [alpha beta]. This Clarke transformation is specific to the case where the primary axis of the 3-phase coordinate system is aligned with the primary axis of the orthogonal coordinate system.
The transform is given by:
Diagram name: Clarke Transform
The following simulation shows the transformation and compares the phase differences as a Lissajous figure.
