Adding and removing connector tabs
You can add or delete connector tabs on many most blocks. If you delete a connector tab with an attached wire, the wire is also deleted.
Because additional connector tabs are unconnected in compound blocks, make sure you verify the input and output connections after you complete this procedure.
To add or remove connector tabs
1.    Do one of the following:
•      Press CTRL+ or CTRL-.
•      From the toolbar, choose  or .
•      Choose Edit > Add Connector or Edit > Remove Connector.
2.    Do one of the following:
•      To add a connector tab: Point to where you want the tab and click.
•      To delete a connector tab: Point to the tab to be deleted and click.
3.    Repeat step 2 for as many tabs that you want to add or delete.
4.    To exit this command, click on empty screen space.
