Building a custom implicit solver
Most languages have a Project Build facility that automates the process of building a DLL file. The following procedure guides you through the process of building a project in general terms. Refer to the documentation for the application language you’re using for specific instructions.
To build a custom implicit solver
1.    Invoke the Compiler environment.
2.    Add all the source files listed under Source files for building a custom implicit solver to the project or make file.
3.    Under Project Options, specify the project type as DLL.
4.    Under Compiler Preprocessor Options, specify \<install-directory>\VSDK as the include directory.
5.    Build the project.
