Monitoring Data in Real Time
You can communicate and exchange data with devices outside the Embed environment in the following ways:
•      Interface with a USB Controller Area Network (CAN) device to read and write CAN messages on the CAN bus
•      Connect to any OPC server and log data or run a virtual plant in Embed for offline tuning
•      Perform real-time data acquisition and signal generation using National Instruments and Measurement Computing I/O cards, PLCs, and DCSs
•      Perform serial I/O with other computers
•      Exchange data over the Ethernet using UDP
