DOPTPRM, PNORM
Bulk Data Entry Specifies the value of the power (or penalty) , used in the Stress NORM Method for stress response calculation in Lattice Structure Optimization.
| Parameter | Values | Description |
| PNORM | Real ≥ 1.0 Default = 6.0 |
The Stress NORM Method is used to approximately calculate the maximum value of the stresses of all the elements included in a particular response. This is also scaled with the stress bounds specified for each element. Therefore, to minimize the maximum stresses in a particular element set, the resulting stress NORM value ( ) is internally constrained to a value lower than 1.0. |
- The stress response will move towards the stress average as PNORM is decreased. It is recommended to use the default value of 6.0, unless its alteration is necessary.
- PNORM values greater than 6.0 converge closer towards the maximum, however, the calculation can possibly become numerically unstable.
