/MAT/LAW53 (TSAI_TAB)
Block Format Keyword Describes the law that is a uni-directional orthotropic elasto-plastic law and is only used with solid elements.
/MAT/LAW53/mat_ID/unit_ID or /MAT/TSAI_TAB/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E11 | E22 | ||||||||
G12 | G23 | ||||||||
fct_ID11 | fct_ID22 | fct_ID12 | fct_ID23 | fct_ID45 | |||||
Fscale11 | Fscale22 | Fscale12 | Fscale23 | Fscale45 |
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density (Real) |
E11 | Young's modulus (Real) |
E22 | Young's modulus (Real) |
G12 | Shear modulus (Real) |
G23 | Shear modulus (Real) |
fct_ID11 | Yield stress function identifier in direction
11 (Integer) |
fct_ID22 | Yield stress function identifier in direction
22 (Integer) |
fct_ID12 | Yield stress function identifier in direction
12 (Integer) |
fct_ID23 | Yield stress function identifier in direction
23 (Integer) |
fct_ID45 | Yield stress function identifier in direction
45 (Integer) |
Fscale11 | Scale factor for yield function 11 Default = 1.0 (Real) |
Fscale22 | Scale factor for yield function 22 Default = 1.0 (Real) |
Fscale12 | Scale factor for yield function 12 Default = 1.0 (Real) |
Fscale23 | Scale factor for yield function 23 Default = 1.0 (Real) |
Fscale45 | Scale factor for yield function 45 Default = 1.0 (Real) |
Example (Plastic)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW53/1/1
plastic
# RHO_I
2E-10
# E11 E22
200 200
# G12 G23
100 100
# fct_ID11 fct_ID22 fct_ID12 fct_ID23 fct_ID45
1 1 3 4 5
# Fscale11 Fscale22 Fscale12 Fscale23 Fscale45
0 0 0 0 0
#- 3. FUNCTIONS:
/FUNCT/1
function_1
# X Y
0 200
.1 200
.11 100
.5 100
1.5 20000
/FUNCT/2
function_2
# X Y
0 1
10000 1
/FUNCT/3
function_3
# X Y
0 200
.1 200
.11 100
.5 100
1.5 20000
/FUNCT/4
function_4
# X Y
0 200
.5 200
1.5 20000
/FUNCT/5
function_5
# X Y
0 100
.5 100
1.5 20000
#ENDDATA
/END
- Orthotropic reference frame (1, 2,
and 3) is defined in the appropriate property set of each finite element.For SOLID property set (/PROP/TYPE14), the global frame is used if Isolid = 1 or 2.
- The global frame is ( , , and ).
- The local frame is (
, and
- The law is othotropic, E33 = E22 and G13 = G12.
- The yield surface is Tsai-Wu yield
criteria:
(1) with(2) (3) (4) The parameters: are variable and introduced by yield function.
- If fct_ID45 ≠
0,
(5)
