/MAT/LAW104
Block Format Keyword An elasto-plastic constitutive law using the 6th order Drücker model with a mixed Voce and linear hardening. Johnson-Cook strain rate dependency and thermal softening effects due to self-heating can also be modeled. The law is available for isotropic shell and solid elements.
| /MAT/LAW104/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | Ires | ||||||||
| H | QV | BV | CDR | ||||||
| CJC | Fcut | ||||||||
| Tref | Tini | ||||||||
| Cp | |||||||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Optional unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material title. (Character, maximum 100 characters) |
| Initial density. (Real) |
| E | Young‘s modulus. (Real) |
| Poisson’s ratio. (Real) |
| Ires | Resolution method for plasticity.
(Integer) |
| Initial yield stress. (Real) |
| H | Linear hardening module. (Real) |
| QV | Voce hardening coefficient. (Real) |
| BV | Voce hardening exponent. (Real) |
| CDR | Drucker coefficient. (Real) |
| CJC | Johnson-Cook strain rate coefficient. (Real) |
| Inviscid limit for the plastic strain
rate. (Real) |
| Fcut | Cutoff frequency for strain rate filtering. Default = 1020 (Real) |
| Temperature softening slope. (Real) |
| Tref | Reference temperature. (Real) |
| Tini | Initial temperature. (Real) |
| Taylor-Quinney coefficient. (Real) |
| Cp | Specific heat. (Real) |
| Plastic strain rate at isothermic
conditions. (Real) |
| Plastic strain rate at adiabatic
- The law uses 6th
order Drücker equivalent stress definition:
(1) Where , are respectively the second and third invariant of the deviatoric stress tensor .
The parameter is user-defined and allows to define several yield surfaces (Figure 1). To respect the convexity, its value must respect -27/8 ≤ CDR ≤ 2.25.
Figure 1. Drücker yield surfaces - The yield function is
defined as:
(2) and(3) Where,- Initial yield stress.
- H
- Linear hardening.
- Voce hardening parameters.
- Johnson-Cook strain rate coefficient.
- Inviscid limit plastic strain rate.
- Thermal softening slope.
The evolution of this flow stress equation with plasticity.
Figure 2. Flow stress evolution with plasticity - If
/HEAT/MAT is not used for this material, the
temperature is calculated internally using the incremental
formula:
(4) Where,- Plastic strain energy increment.
- Taylor-Quinney coefficient that must respect .
- Coefficient that defines the transition between isothermal and adiabatic conditions (Figure 3).
(5)
Figure 3. Evolution of the temperature weight with the plastic strain rate - The plastic strain rate is filtered, as described in Filtering in the User Guide.
