/MAT/LAW64 (UGINE_ALZ)
Block Format Keyword This law describes the Ugine & Alz trip steel material. This material law can be used only with shell elements.
/MAT/LAW64/mat_ID/unit_ID or /MAT/UGINE_ALZ/mat_ID/unit_ID
mat_title
ρ i
E ν Cp
D n Md V0 Vm
fct_ID0 fct_ID1 Fscale0 Fscale1 T0
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Initial Young's modulus.
(Real)
[ Pa ]
ν Poisson's ratio.
(Real)
Cp Specific heat capacity.
Default = 1030 (Real)
[ J kgK ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabQeaaeaacaqGRbGaae4zaiabgwSixlaabUeaaaaacaGL BbGaayzxaaaaaa@3DB3@
D Material parameter 1.
(Real)
n Material parameter 2.
(Real)
Md Limit martensite transformation temperature.
(Real)
[ K ]
V0 Material parameter.
(Real)
Vm Constant martensite fraction for second yield stress function 0 < Vm ≤ 1.
(Real)
fct_ID0 Yield stress function identifier for 0 martensite fraction.
(Integer)
fct_ID1 Yield stress function identifier for Vm martensite fraction.
(Integer)
Fscale0 Scale factor for yield function for fct_ID0.
(Real)
[ Pa ]
Fscale1 Scale factor for yield function for fct_ID1.
(Real)
[ Pa ]
T0 Initial temperature.
(Real)
[ K ]
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW64/1/1
Steel
#              RHO_I
              7.8E-9
#                  E                  Nu                  Cp
              210000                  .3           460000000
#                  D                   n                  Md                  V0                  Vm
                   4                 3.5                 356                  .2                  .6
# func_ID0  func_ID1             Fscale0             Fscale1                  T0
         1         2                   1                   1                 323
#-  3. FUNCTIONS:
/FUNCT/1
function_1
#                  X                   Y
                   0                 250
                .001                 350
                  .5                1100
/FUNCT/2
function_2
#                  X                   Y
                   0                 930
                .001                1000
                  .5                1500
#ENDDATA
/END
  1. Martensite fraction:(1)
    V m ( ε p , T ) = V m max ( T ) ( 1 e ( D ε p ) n )
    (2)
    V m max ( T ) = V 0 Ln ( M d T + 1 )
    if (3)
    T < M d
    (4)
    V m max ( T ) = 0
    if (5)
    T > M d
  2. Mechanical behavior:
    The yield plastic stress is computed by linear interpolation between two curves fct_ID1 and fct_ID0.
  3. The temperature is computed assuming the adiabatic condition (by default the condition is isothermal with Cp = 1030):(6)
    T = T 0 + E int ρ C p ( Volume )
    Where, Eint is the internal energy of the element.
