/MAT/LAW22 (DAMA)
Block Format Keyword This law is identical to Johnson-Cook material (/MAT/LAW2), except that the material undergoes damage if plastic strains reach a user-defined value ( ). This law can be applied to both shell and solid elements.
/MAT/LAW22/mat_ID/unit_ID or /MAT/DAMA/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E | |||||||||
a | b | n | |||||||
c | ICC | ||||||||
Et |
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Initial
density (Real) |
E | Young's
modulus (Real) |
Poisson's
ratio (Real) |
a | Yield stress - should be
strictly positive. (Real) |
b | Hardening
parameter. (Real) |
n | Hardening
exponent (Real) |
Failure plastic
strain Default = 1030 (Real) |
Maximum stress Default = 1030 (Real) |
c | Strain rate coefficient.
Default = 0.00 (Real) |
Reference strain
rate. If , no strain rate effect. (Real) |
ICC | Strain rate computation
flag. 2
(Integer) |
Damage model starts
at
. Default = 0.15 (Real) |
Et | Softening damage slope (
). Default = 0.00 (Real) |
Example (Aluminum)
#RADIOSS STARTER
/UNIT/1
unit for mat
g mm ms
#- 2. MATERIALS:
/MAT/DAMA/1/1
Alu
# RHO_I
.0027
# E Nu
70000 .3
# a b n Eps_max SIGMA_max0
100 0 1 .2 100
# c Eps_dot_0 ICC
0 0 0
# Eps_dam E_t
.1 -2000
#ENDDATA
/END
- Damage is isotropic, its effect
are the same in tension and compression.
(1) Where,- Plastic strain
- Strain rate
- ICC is a flag of the strain rate
effect on material maximum stress
- The damage appears in the
material when the strain is larger than a maximum value
(2) If , Law 22 is identical to law /MAT/LAW2.
If and
Figure 2. - For solid elements, the damage law can only be applied to the deviatoric stress tensor sij and .
- When
reaches
in one integration point, then based on the element
type:
- Shell elements: The corresponding shell element is deleted.
- Solid elements: The deviatoric stress of the corresponding integral point is permanently set to 0, however, the solid element is not deleted.
