RD-E: 1100 Tensile Test
Material characterization using a tensile test.
The Radioss material laws 2 and 36 are used to reproduce the experimental data of a tensile test by simulation. The work-hardening, damage, and rupture of the object are simulated by a finite element model. The parameters of the material laws are determined to fit the experimental results.
