RD-E: 4600 TNT Cylinder Expansion Test
The Cylinder Expansion Test is an experimental test used to characterize the adiabatic expansion of detonation products. It allows determining JWL EOS parameters.
![ex46_summary](../../../images/solvers/ex46_summary.png)
- 3D mesh of a quarter-cylinder with eight node brick elements
- Jones-Wilkins-Lee Equation-of-State for TNT detonation products (/MAT/JWL)
- Hydrodynamic Johnson-Cook material law for the copper cylinder (/MAT/HYD_JCOOK)
- Multi-Material, Fluid and Explosive material law (/MAT/LAW51)
The simulation results are then compared to the experiment data.
