*SECTION_SHELL
LS-DYNA Input Interface KeywordDefines the shell element properties.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SECTION_SHELL | |||||||
| sec_ID | ELFORM | NIP | |||||
| Thick | |||||||
Definition
| sec_ID | Section identifier of the elements in the
part. (Integer) |
| ELFORM | Shell element formulation options.
(Integer) |
| NIP | Number of integration points through the thickness with 0
< N < 10.
(Integer) |
| Thick | Shell thickness. (Real) |
- This keyword maps to /PROP/TYPE1 (SHELL) for an isotropic material and /PROP/TYPE9 (SH_ORTH) for an orthotropic material.
- The recommended shear correction factor 5/6 is always used.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
