*SET_PART
LS-DYNA Input Interface KeywordDefines a set of parts based on a list or generates a list by specifying a range of part IDs.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_PART_{OPTION} | |||||||
| set_ID | |||||||
| PID1 | PID2 | PID3 | PID4 | PID5 | PID6 | PID7 | PID8 |
| PIDB1 | PIDE1 | PIDB2 | PIDE2 | PIDB3 | PIDE3 | PIDB4 | PIDE4 |
| PIDB | PIDE | INCR |
| PID |
Definition
| OPTION |
| set_ID | Part set identifier. (Integer) |
| PID1 - PID8 | Part IDs, 8 per line. (Integer) |
| PIDB1 - PIDB4 | First part ID of the range, up to 4 per
line. (Integer) |
| PIDE1 - PIDE4 | Last part ID of the range, up to 4 per
line. (Integer) |
| PIDB | First part ID of the range. (Integer) |
| PIDE | Last part ID of the range. (Integer) |
| INCR | Increment value for the list generation from
PIDB to PIDE.
Default = 1 (Integer) |
| PID | Part ID, 1 per line. (Integer) |
- This keyword maps to /SET/GENERAL.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
