*MAT_S01 (SPRING_ELASTIC)
LS-DYNA Input Interface KeywordDefines a linear spring material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_S01 or *MAT_SPRING_ELASTIC | |||||||
| mat_title | |||||||
| mat_ID | K | ||||||
Definition
| mat_ID | Material identifier. (Integer) |
| K | Linear stiffness. (Real) |
- This keyword maps to /MAT/LAW108 (SPR_GENE).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
