LS-DYNA Input Interface KeywordDefines a surface defined by 3 or 4 nodes segments.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
*SET_SEGMENT_{OPTION1} |
set_ID |
If
OPTION1 =
<BLANK>, repeat the following
line, as needed.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
N_ID1 |
N_ID2 |
N_ID3 |
N_ID4 |
If
OPTION1 =
GENERAL
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
TYPE |
E1 |
E2 |
E3 |
E4 |
E5 |
E6 |
E7 |
Definition
Field |
Contents |
SI Unit Example |
OPTION1 |
- BLANK
- GENERAL
set_ID |
Node set identifier. (Integer)
N_ID1 - N_ID4 |
Node IDs, 4 per line. (Integer)
TYPE |
- BOX
- The external segment inside the listed boxes are
added to the set E1 to
E3.
- BOX_SHELL
- Add segment from shell element inside the listed
boxes are added to the set E1 to
E3.
- BOX_SLDIO
E3.
- BOX_SOLID
- Add segment from solid element inside the listed
E7.
- DBOX
- Remove segment from shell or solid element inside
the listed boxes are added to the set.
- DBOX_SHELL
- Remove segment from solid element inside the listed
E7.
- DBOX_SOLID
E1 to
E7.
- DPART
- Remove segment from part inside the listed boxes are
E7.
- DSEG
- Remove segment defined by nodes
E1 to
E4.
- PART
- Add external segment from part list
E1 to
E3.
- PART_IO
- Add all segment from part list E1
to E3.
- SEG
E1 to
E4.
- SET_SHELL
- Add external segment from shell set list
E1 to
E3.
- SET_SOLID
- Add external segment from solid set list
E1 to
E3.
- SET_SLDIO
- Add all segment from solid set list
E1 to
E3.
- SET_TSHELL
- Add external segment from thick shell set list
E1 to
E3.
- SET_TSHIO
- Add all segment from thick shell set list
E1 to
E3.
- SHELL
- Add segment from shell list E1 to
E3.
No default
E1 - E7 |
Entity IDs, 7 per line (Integer)
- This keyword maps to /SET/GENERAL.
- The option “_TITLE” can be added
to the end of this keyword. When “_TITLE” is included, an
extra 80 characters long line is added after the keyword input line which
allows an entity title to be defined.
