*DATABASE
LS-DYNA Input Interface KeywordDefines the output frequency for time history data.
(1) (2) (3) (4) (5) (6) (7) (8)
*DATABASE_{OPTION}
DT
Definition
OPTION Time history output type.
ABSTAT
Airbag data
BNDOUT
Nodal reaction force for imposed movement
DEFORC
Spring
DISBOUT
Beam element
ELOUT
Element
GLSTAT
Global variable
JNTFORC
Joint
MATSUM
Energy by parts
NODOUT
Node displacement and rotation
RBDOUT
Rigid body movement
RCFORC
Resultant contact force
RWFORC
Rigid wall
SECFORC
Cross section force
SPCFORC
Boundary condition force
SWFORC
Spotweld force
DT Time frequency for writing time history output.
(Real)
[ s ]
  1. This keyword maps to /TFILE/4. The minimum time interval from all the *DATABASE_{OPTION} defined is used.
  2. The card controls only the frequency of the output. An additional card may need to be defined to specify which objects will be output. For example, number of nodes, elements, the definition of section force, and so forth.
