Engine Keyword Defines the frequency of writing the time history file
of T-file "RunnameTnn".
/TFILE/Type
Field |
Contents |
SI Unit Example |
Type |
No value: Built-in
format of current Radioss version.
- = 1
- Binary (not readable by most Radioss post-processors)
- = 2
- Coded ASCII
32-bit
- = 3
- ASCII
- = 4 (Default)
- Binary IEEE 32-bit
Time frequency to
write data on history plot file T-file. |
- Recommended options are default (no
value) or four, which can be read by HyperGraph.
- See "File Extensions and Formats" for detail on T-file
name.
