*MAT_099 (SIMPLIFIED_JOHNSON_COOK_ORTHOTROPIC_DAMAGE)
LS-DYNA Input Interface KeywordDefines an an isotropic elasto-plastic material using the Johnson-Cook material model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_098 or *MAT_SIMPLIFIED_JOHNSON_COOK_ORTHOTROPIC_DAMAGE | |||||||
| mat_ID | E | ν | |||||
| a | b | n | c | FAIL | |||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E | Young’s modulus. (Real) |
| v | Poisson’s ratio. Default = 0 (Real) |
| Failure plastic strain. Default = 1030 (Real) |
| a | Yield stress. (Real) |
| b | Hardening coefficient. (Real) |
| n | Hardening exponent. (Real) |
| c | Strain rate coefficient. (Real) |
| FAIL | Principal plastic strain to failure. (Real) |
| Maximum stress limit. (Real) |
| Reference strain rate. (Real) |
- This keyword maps to /MAT/LAW2 (PLAS_JOHNS) and /FAIL/FLD.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
