*AIRBAG_SIMPLE_AIRBAG_MODEL
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag with uniform pressure method, injected gas and vent hole.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *AIRBAG_SIMPLE_AIRBAG_MODEL_{OPTION} | |||||||
| monvol_ID | Title | ||||||
| surf_IDex | Surf_typ | ||||||
| CV | CP | T | fct_IDM | MU | AREA | Pext | |
| fct_IDp | Text | Cpa | Cpb | MW | GASC |
Definition
| monvol_ID | Airbag identifier. (Integer) |
| Title | Title. (character) |
| surf_IDex | Airbag external surface identifier. (Integer) |
| Surf_typ | Set type.
(Integer) |
| CV | Heat capacity at constant volume. (Real) |
| CP | Heat capacity at constant pressure. (Real) |
| T | Input gas temperature. (Real) |
| fct_IDM | Mass flow rate of injected gas versus time function
| MU | Vent hole shape.
Default = 1 (Real) |
| Area | Vent hole area.
(Real) |
| Pext | External pressure. (Real) |
| Ambient density (used if
CV=0). Default = (Real) |
| fct_IDp | Vent hole mass flow out function versus absolute pressure
(used if
CV=0). (Integer) |
| Text | External temperature. Default = 295 K (Real) |
| Cpa | First heat capacity coefficient of injected gas (used if
CV=0). (Real) |
| Cpb | First heat capacity coefficient of injected gas (used if
CV=0). (Real) |
| MW | Molecular weight of gas(used if
CV=0). (Real > 0) |
| GASC | Universal gas constant
(used if
CV=0). (Real) |
- This keyword maps to /MONVOL/AIRBAG1, /MAT/GAS, and /PROP/INJECT1.
- Vent option defined with function fct_IDp can be used only if CV = 0.
