*INITIAL_VELOCITY
LS-DYNA Input Interface KeywordThis keyword defines initial velocity of a node set.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*INITIAL_VELOCITY | |||||||
set_ID | IRIGID | CID | |||||
VX | VY | VZ | VXR | VYR | VZR |
Definition
set_ID | Node set identifier.
(Integer) |
IRIGID | Option to overwrite velocities defined in
*PART_INERTIA or
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA.
CID | Coordinate system identifier. (Integer) |
VX, VY, VZ | Translational nodal velocity components. | |
VXR, VYR, VZR | Rotational nodal velocity components. |
- This keyword maps to /INIVEL.
