*RIGIDWALL_PLANAR
LS-DYNA Input Interface KeywordThis keyword defines a planar rigid wall kinematic condition.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *RIGIDWALL_PLANAR_{OPTION}_{OPTION}_{OPTION} | |||||||
| ID | |||||||
| NSID | NSEDX | Dsearch | |||||
| XT | YT | ZT | XH | YH | ZH | FRIC |
| XHEV | YHEV | ZHEV | LENL | LENM |
| Mass | V0 |
Definition
| OPTION | Rigid wall type.
| NSID | Secondary node to the rigid wall. | |
| NSEDX | Secondary nodes excluded from rigid wall. | |
| Dsearch | Search distance, used when NSID =
0. Dsearch = 1e20 Default used when secondary nodal set is not specified. (Real) |
| XT, YT, ZT | Coordinates of tail of rigid wall normal
vector. (Real) |
| XH, YH, ZH | Coordinates of head of rigid wall normal
vector. (Real) |
| XHEV, YHEV, ZHEV | Coordinates of edge of rigid wall
vector. (Real) |
| LENL, LENM | Size of the finite rigid wall. | |
| Mass | Mass of rigid wall. | |
| V0 | Initial velocity of rigid wall. In case Mass = 0 this is imposed velocity. |
- This keyword maps to /RWALL or RWALL/PARAL.
