*INITIAL_VELOCITY_NODE
LS-DYNA Input Interface KeywordThis keyword defines an initial translational and rotational velocity of a node.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *INITIAL_VELOCITY_NODE | |||||||
| node_ID | VX | VY | VZ | VXR | VYR | VZR | |
Definition
| node_ID | Node number. (Integer) |
| VX, VY, VZ | Translational nodal velocity components. | |
| VXR, VYR, VZR | Rotational nodal velocity components. |
- This keyword maps to /INIVEL.
- If the node_ID is a secondary node of a rigid body, the initial velocity is not applied to the node.
