*MAT_067 (NONLINEAR_ELASTIC_DISCRETE_BEAM)
LS-DYNA Input Interface KeywordThis keyword defines a non-linear elastic discrete beam material with 6 decoupled DOFs with an optional preload.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_067 or *MAT_NONLINEAR_ELASTIC_DISCRETE_BEAM | |||||||
| mat_ID | T_r | T_s | T_t | R_r | R_s | R_t | |
| TD_r | TD_s | TD_t | RD_r | RD_s | RD_t | ||
| FO_r | FO_s | FO_t | MO_r | MO_s | MO_t | ||
| FFAIL_r | FFAIL_s | FFAIL_t | MFAIL_r | MFAIL_s | MFAIL_t | ||
| UFAIL_r | UFAIL_s | UFAIL_t | TFAIL_r | TFAIL_s | TFAIL_t | ||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| Initial density. (Real) |
| T_r, T_s, T_t | Curve identifier for force versus displacement loading curve
in the r, s, and t directions. (Integer) |
| R_r, R_s, R_t | Curve identifier for moment versus rotation loading curve in
| TD_r, TD_s, TD_t | Curve identifier for force versus velocity damping curve in
| RD_r, RD_s, RD_t | Curve identifier for moment versus rotational velocity
damping curve in the r, s, and t
| FO_r, FO_s, FO_t | Force preload in directions r, s, t. | |
| MO_r, MO_s, MO_t | Moment preload in directions r, s, t. | |
| FFAIL_r, FFAIL_s, FFAIL_t | Failure forces in directions r, s, t. | |
| MFAIL_r, MFAIL_s, MFAIL_t | Failure moments in directions r, s, t. | |
| UFAIL_r, UFAIL_s, UFAIL_t | Failure elongations in directions r, s, t. | |
| TFAIL_r, TFAIL_s, TFAIL_t | Failure rotation angles in directions r, s, t. |
- This keyword maps to /MAT/LAW108 (SPR_GENE).
- The material is only used with *SECTION_BEAM, ELFORM = 6 discrete beam elements.
- Beams with zero initial length are recommended.
- Force versus displacement and moment versus angle curves can be specified in the 1st quadrant only. The spring will behavior in compression will be a mirror of the entered curve and so that compression and tension behavior will be the same.
- The damping curve is symmetric in compression and tension and should be defined in the 1st quadrant starting with the point 0, 0.
- If for a DOF both force-based and displacement-based failure is defined, then only the displacement failure will be used.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
