*MAT_018 (POWER_LAW_PLASTICITY)
LS-DYNA Input Interface KeywordThis model expresses isotropic plasticity model with rate effects which uses a power law hardening.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_018 or *MAT_POWER_LAW_PLASTICITY
mat_ID ρ i E v K N c p
SIGY VP
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young’s modulus.
(Real)
[ Pa ]
v Poisson’s ratio.
(Real)
K Yield stress.
(Real)
[ Pa ]
N Plasticity hardening exponent.
Default = 1.0 (Real)
[ Pa ]
c Strain rate coefficient.
= 0 (Default)
No strain rate effect.
(Real)
[ 1 s ]
p Strain rate exponent.
SIGY Optional yield stress value.
(Real)
[ Pa ]
VP Formulation for rate effects:
= 0
Total strain rate.
= 1
Viscoplastic strain rate.
(Integer)
ε p m a x Plasticity maximum stress.
Default = 1030 (Real)
  1. This keyword maps to /MAT/LAW44 (COWPER) + /FAIL/JOHNSON.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
