LS-DYNA Input Interface KeywordThis model expresses a one-chambered airbag with pressure as a function of
volume.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
*AIRBAG_SIMPLE_PRESSURE_VOLUME_{OPTION} |
If
OPTION =
ID, insert the following
line.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
ID |
Title |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
surf_IDex |
Surf_typ |
CN |
BETA |
Definition
Field |
Contents |
SI Unit Example |
ID |
Airbag identifier. (Integer)
Title |
Title. (Character)
surf_IDex |
Airbag external surface identifier. (Integer)
Surf_typ |
Set type.
- ≠ 0
- Set of parts.
CN |
Pressure coefficient.
- > 0
(Real)
BETA |
Pressure scale factor. (Real)
- This keyword maps to /MONVOL/PRES.
- Relative volume is defined as:(1)
