/PROP/INJECT1
Block Format Keyword Describes mass injected for each constituent gas.
/PROP/INJECT1/inject_ID/unit_ID
inject_title
Ngases Iflow AscaleT
Define mixture data for Ngases gases:
mat_ID1 fct _ I D M 1 fct _ I D T 1   Fscal e M 1 Fscal e T 1
mat_ID2 fct _ I D M 2 fct _ I D T 2   Fscal e M 2 Fscal e T 2
etc
mat_IDN fct _ I D M N fct _ I D N T   Fscal e M N Fscal e T N
inject_ID Injector identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
inject_title Injector title
Ngases Number of gases.
(Integer)
Iflow Mass entity versus time function input type flag.
= 0
Mass is input
= 1
Mass flow is input - the input scale factor on time is also applied to mass flow
(Integer)
AscaleT Abscissa scale factor for time based functions.
Default = 1.0 (Real)
[ s ]
mat_IDi Material identifier that identifies the gas.
(Integer)
fct _ I D M i Mass of injected gas versus time function identifier (i=1,2...N).
(Integer)
Fscal e M i Mass function scale factor (i=1,2...N).
[ kg ] or [ kg s ]
fct _ I D T i Temperature of injected gas versus time function identifier (i=1,2...N).
(Integer)
Fscal e T i Temperature function scale factor (i=1,2...N).
[ K ]
