/PROP/TYPE9 (SH_ORTH)
Block Format Keyword This property set is used to define the orthotropic shell property.
/PROP/TYPE9/prop_ID/unit_ID or /PROP/SH_ORTH/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
Ishell | Ismstr | Ish3n | Idril | P_thickfail | |||||
hm | hf | hr | dm | dn | |||||
N | Istrain | Thick | Ashear | Ithick | Iplas | ||||
VX | VY | VZ |
prop_ID | Property
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
prop_title | Property
title. (Character, maximum 100 characters) |
Ishell | Shell element formulation
flag. 1
(Integer) |
Ismstr | Shell small strain
formulation flag. 2
(Integer) |
Ish3n | 3 node shell element
formulation flag.
(Integer) |
Idril | Drilling degree of freedom
stiffness flag. 7
(Integer) |
P_thickfail | Percentage of through thickness integration points that must fail
before the element is deleted. 9
10 (Real) |
hm | Shell membrane hourglass
coefficient. 3 Default = 0.01 Default = 0.1 for hourglass type 3 (Ishell =3) (Real) |
hf | Shell out-of-plane
hourglass. 3 Default = 0.01 Default = 0.1 for hourglass type 3 (Ishell =3) (Real) |
hr | Shell rotation hourglass
dm | Shell Membrane Damping It is only active for Material Laws 19, 25, 32 and 36. Default =1.5% for Ishell =24 (QEPH)+LAW19, 32 and 36. Default =5.0% for Ishell =24 (QEPH)+LAW25 Default =0.0% for Ishell =12 (QBAT) Default =5.0% for Ishell =1,2,3,4 (Q4)+LAW25 Default =25.0% for Ishell =1,2,3,4 (Q4)+LAW19 Default =0.0% for Ishell =1,2,3,4 (Q4)+LAW32 and 36 (Real) |
dn | Shell numerical damping.
4 It only used for Ishell =12 and 24. Default =1.5% for Ishell =24 (QEPH) Default =0.1% for Ishell =12 (QBAT) Default =0.01% for Ish3n =30 (DKT18) (Real) |
N | Number of integration
points through the thickness 1 < N <
10. Default set to 1 (Integer) |
Istrain | Compute strains for
post-processing flag.
(Integer) |
Thick | Shell
thickness. (Real) |
Ashear | Shear factor. Default is Reissner value: 5/6 (Real) |
Ithick | Shell resultant stresses
calculation flag.
(Integer) |
Iplas | Shell plane stress
plasticity flag. 6 It is available for Material Laws 2, 22, 32,
36 and 43.
(Integer) |
VX | X component. 8 Default = 1.0 (Real) |
VY | Y component. 8 Default = 0.0 (Real) |
VZ | Z component. 8 Default = 0.0 (Real) |
Angle. 8 Default = 0.0 (Real) |
#RADIOSS STARTER
#- 1. LOCAL_UNIT_SYSTEM:
/UNIT/2
unit for prop
# MUNIT LUNIT TUNIT
kg mm ms
#- 2. GEOMETRICAL SETS:
/PROP/SH_ORTH/2/2
SH_ORTH example
# Ishell Ismstr Ish3n Idrill
12 0 0 1
# hm hf hr dm dn
0 0 0 .1 .1
# N Istrain Thick Ashear Ithick Iplas
3 0 1.8 0 1 1
# Vx Vy Vz Phi
1 0 1 45
#enddata
- Ishell. Ish3n – 4-node and 3-node shell
formulation flag
- Ishell =1,2,3,4 (Q4): original 4 node Radioss shell with hourglass perturbation stabilization.
- Ishell =24 (QEPH): formulation with hourglass physical stabilization for general use.
- Ishell =12 (QBAT): modified BATOZ Q4γ24 shell with four Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell.
- Ish3n =30 (DKT18): BATOZ DKT18 thin shell with three Hammer integration points.
- Flag Ishell =2 is incompatible with one integration point for shell element.
- Ish3n - Small strain
formulation
- Small strain formulation is activated from time t= 0, if Ismstr = 1, 3 or 11. It may be used for a faster preliminary analysis, but the accuracy of results is not ensured. Any shell for which can be switched to a small strain formulation by Radioss Engine option /DT/SHELL/CST, except if Ismstr = 4 or 11.
- If Ismstr =1, 3 or 11, the strains and stresses which are given in material laws are engineering strains and stresses; otherwise they are true strains and stresses.
- Ismstr =11 has been developed to improve the robustness for Airbag models; actually it is only compatible with Law 19 and with all quadrilateral shells and standard C0 tria. For Q4 shell using reference state coordinates, when Ismstr = 1, it will be set automatically to Ismstr = 11.
- hm, hf, and hr - Hourglass coefficients
- hm, hf, and hr are only used for Q4 shells (Ishell=1,2,3,4). They must have a value between 0 and 0.05.
- For Ishell=3, default values of hm and hr are 0.1 with larger values possible.
- dn - Shell
numerical damping coefficient
- dn is only used for Ishell =12 and 24 and
Ish3n=30:
- for Ishell = 24, dn is used for hourglass stress calculation
- for Ishell = =12 (QBAT) dn is used for all stress terms, except transvers shear
- for Ish3n=30 (DKT18) dn is only used for membrane
Ish3n=30:
- Ithick - Shell resultant
stresses calculation flag
- Flag Ithick is automatically set to 1 for /MAT/LAW32 (HILL).
- If Ithick=1, the small strain option is automatically deactivated in the corresponding type of element.
- Iplas - Shell plane stress
plasticity flag
- It is recommended to use Iplas = 1, if Ithick = 1.
- If Iplas =1, the small strain option is automatically deactivated in the corresponding type of element.
- Idril - Drilling degree of
freedom stiffness flag
- Drilling DOF stiffness is recommended for implicit solutions especially for Riks method and bending dominated problems.
- Idril is available for QEPH, QBAT (Ishell = 12 and 24), and standard triangle (C0) shell elements (Ish3n = 1 and 2).
- Orthotropy in local
coordinate system:
- Orthotropic direction defined with global vector (components defined in Line 6) and angle (angle in degree).
- Projection of vector
on shell element plane becomes the
vector
. Next, the element's orthotropic
direction (direction 1) vector
is turned
degrees; where, positive rotation is based on
the shell normal
Figure 2. - In case of reference metrics, the orientation for directions of anisotropy must be defined with the reference geometry, not the initial one.
- P_thickfail parameter is not compatible with failure defined within the material law itself, such as plastic failure strain in LAW36.
- Element deletion rules
used with /FAIL models:
- Under-integrated elements (Belytchko, QEPH, DKT18):
- If more than one failure model is applied to the shell material,
or
P_thickfail=0
(blank), the value of
P_thickfail
is calculated individually from each failure model settings. Example:
- Ifail_sh = 1
- One integration point failure sufficient to delete element, then P_thickfail= 1.0 e-6
- Ifail_sh = 2
- All integration points failure is necessary to delete the element, thenP_thickfail= 1.0
- If only one failure model is applied to the material, the P_thickfail value from the property is taken by default and overwrites local Ifail_sh settings from the failure model.
or
P_thickfail=0
P_thickfail
- Fully integrated shells (Batoz, DKT_S3):
- The rule described for under-integrated shells applies to each Gauss point separately. P_thickfail ratio is checked for all integration points in thickness for each in-plane Gauss point. The element is deleted only when all Gauss points reach P_thickfail ratio criteria.
