Wheel Vertical Displacement and Vertical Force
Branch ID: 0
Request Number: 80000000
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Wheel Center Vertical Displacement mm The global vertical displacement of the left wheel. The sign is positive when the wheel center moves up (jounce) and negative when the wheel center moves down (rebound).
F3 RESULT(3) Right Wheel Center Vertical Displacement mm The global vertical displacement of the right wheel. The sign is positive when the wheel center moves up (jounce) and negative when the wheel center moves down (rebound).
F4 RESULT(4) Average Wheel Center Vertical Displacement mm The mean of the left and right wheel center vertical displacement.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Wheel Center Vertical Force N The global vertical force between the left wheel part and the jack (vertical constraint) mechanism.
F7 RESULT(7) Right Wheel Center Vertical Force N The global vertical force between the right wheel part and the jack (vertical constraint) mechanism.
F8 RESULT(8) Average Wheel Center Vertical Force N The mean of the left and right wheel center vertical force.
